Chris Waldon Posted July 14, 2009 Share Posted July 14, 2009 I'm going to forge an old file into a dagger tomorrow, and I plan to forge the shape and then use a file to form the actual cutting edge. Will this have any negative impact on the blade's strength or other properties? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted July 14, 2009 Share Posted July 14, 2009 Not if you use good forging procedures and get the heat treat correct when it is all shaped. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 14, 2009 Share Posted July 14, 2009 Do a good anneal on it after forging to shape! Your proposal is a very common way to do it. Don't forget to leave the edge a bit thick before heat treat, it's a pain to reduce after heat treat but really helps control warping or cracking on the edge. Quote Link to comment Share on other sites More sharing options...
bbehnke Posted July 15, 2009 Share Posted July 15, 2009 It wouldn't hurt to grind the edges of the file before forging to remove any stress risers (to reduce the chance of it cracking). Quote Link to comment Share on other sites More sharing options...
Chris Waldon Posted July 15, 2009 Author Share Posted July 15, 2009 what do you mean by "grind the edges of the file"? I've ground the teeth off. Is that what you mean? Quote Link to comment Share on other sites More sharing options...
bbehnke Posted July 15, 2009 Share Posted July 15, 2009 Yes, I meant to grind the teeth. Quote Link to comment Share on other sites More sharing options...
