I don't believe you can weld tungsten, it is used in the welding field as the electrode in GTAW/TIG welding process==Gas Tungsten Arc Welding/Tungsten Inert Gas. BUT don't throw it away...IIRC, Hofi has used the stuff for drifts. Albert Habermann, as the MasterSmith, and Hofi along with some of Hofi's folks, slit and drifted 4" solid and passed 4" solid through the hole several years ago. They used tungsten as the drifts and maybe as the slitter also, not sure about that, but tungsten was used on this project. I saw a video of this when I took my class at Tom Clark's several years back. I believe the tungsten was from spent mortar rounds that Hofi got in Isreal.
I think it would shatter if you tried to forge it, especially it being that small. Tungsten will break, does not bend.
Edited by Thomas Dean
Tungsten is hard to weld, but it is weldable. I have in my garage several tungsten filler rods that can be used to weld tungsten with TIG. And yes, you would also use tungsten electrodes to make the arc. The filler rod is not the same as the electrode.
The difficulties of welding tungsten are twofold: first, it has a very high melting point, and second, it quickly oxidizes in open air, so it needs a inert atmosphere to prevent oxidation.
It would seem that the tungsten electrode would melt when you got the tungsten you are welding hot enough to weld. I have said it before and will continue to say it..."I woke up this morning at the perfect age to learn something new." I would love to see it done! Do you have some pics of tungsten that has been welded? I will have to check into this...
Sam you can not weld tungsten you can braze the tungsten with silver rod.
and you can not forge it .The tungsten will shutter !!! be carfull !!!!!!!!!
All my tools are ''HOT FIT'' AND IF YOU DO IT YOU MUST TAKE UNDER CONSIDERATION THAT THE EXPANTION/SHRINK FACTOR IS DIFFERENT THEN THE MANDREL YOU PUT ON!!
The whole system is explained on -hofi 1013 BP-
I attuch more tooling that I made the last half a year.
Before you start you must check if the tungsten you have is hard or soft with a file if it is the hard one you can do nothing only the soft one you can file or grind or cut on the lathe.
Thomas Dean the name is ALFRED and not ALBERT.
The attuched 4'' round in 4''round is the one I made in my smithy and I still have it with me while Habermman was in my smithy and I showed him the slitting possibility with the tungsten whice he never new about it before
HOFI
15219.attach
15220.attach
Yes, my bad, my fingers got away with me!;)
Also, I think the tungsten ichudov may be referring to is Tungsten Carbide, that you can TIG, as applying it to saw blade teeth for an example. Not quite the same stuff as what is coming out of the lamps that Sam has.
I dont believe so. I've only seen tungsten carbide being brazed on to the tool base.
__________________
Freelance Fabber is right as I said on the thread befor the TUNGSTEN CARBIDE can be brazed only !! brazing= glue .
Hofi
You may already know this but if the bulbs are still intact BE VERY CAREFUL WITH THEM - they are high pressure bulbs (I believe it's filled with Xenon) and the glass is optically pure so it won't show up on an x-ray meaning they'll have to find the glass by you telling them where it hurts.... I was next to a lamp house when the bulb exploded upon startup - this was a 5,000 watt bulb and sounded like a shotgun! It completely shattered the large mirror behind it. When we changed the bulbs we wore a full face shield and a chest protector.
Sam, Are the arc lamos in question 5 year sold 10 year sold? older..? It might just be better to dispose of them properly. Some older lamps may have mercury vapor in them, or other stuff, If you don't know, then proper disposal might be the order of the day.
I am not sure what kind of lamps you have, are they single or dual envelope?
As far as I know tungsten is not radioactive, but thorium gets added to TIG rods to make them strike better. Those rods are only slightly radioactive (ie not harmful, but detectable levels) To my understanding from a long conversation here recently.
Sam, there are so many different varieties of lamps, and disposal procedures, I just tend to be wary. If disposal procedure says to break the envelope, go with it. I have seen high temp high pressure sodium vapor lamps hand grenade (kaboom! ugly ugly stuff) and I know that mercury vapor is the best way to get mercury poisoning. Also there tends to be lots of "rare earth" elements in some types.
Once in a while I look at stuff and say that cool whatever it is, only to say that "what is it? " If i don't know then it stays wherever it is. I heard a story of a guy that worked at Pratt and Whitney, that used a jet engine part to stir his coffee. Turns out it was an exotic radioactive alloy, that basically poisoned him. And he never knew. The building as doing a "WMD" excercise and he registered high with a geiger counter. Left in an ambulance.
I was thinking of an air rifle from a distance... fun and educational!
So, what it boils down to is: It can be ground but not forged, brazed but not welded and has a high scrap value.
Sam, I get TC nozzles made for the grit blasters I make, they are workable until they get sintered, then it is as everyone has said above, They can be broken down and recycled into a lower grade. I can ask my supplier for you if you want.
The nozzles I have shatter very easily but last ages.
David.
