Tempering an RRspike knife.
Don't know if a propane torch will be enough, you need to heat the blade till it's glowing, slightly above the temperature where a magnet will lose it's attraction to it and then quench in cold salt water. This will harden it. Probably not need much tempering but if you want to I would ssuggest 325 deg F in a kitchen oven for 1 hour.
