markb Posted June 23, 2009 Share Posted June 23, 2009 I don't know if this is the place to post these pic's but I got all excited about doing a hollow grind. 10" wheel KMG 1/4"x11/4 mild steel marked 2 guide lines aprox. .050 I started out to do single edge grind but couldn't help trying the double edge, so I had no center line, made a push stick out of oak flooring piece, and followed the chat tutorial didn't concentrate on the plunge too much with everything going on with position etc. Off to burn up more stock. Thanks for looking Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted June 24, 2009 Share Posted June 24, 2009 REAlly good start Mark Quote Link to comment Share on other sites More sharing options...
mcraigl Posted June 24, 2009 Share Posted June 24, 2009 Nice Mark. Get all practiced up on that, so I can come over and watch how it's done. I still need to get a bigger contact wheel for my grinder. Did you get your 10" wheel from KMG, or another source? Is 10" the optimum size to get? Quote Link to comment Share on other sites More sharing options...
markb Posted June 24, 2009 Author Share Posted June 24, 2009 Thanks for looking Rich. Mike, I got the 10" from KMG. As to optimum size ,I don't know, many people seem to use 8" I went with 10" for a little flatter grind, It may be easier to grind with an 8" because of the tighter arc, when you establish the dish in your blade it kinda clicks in when you press the blade to the wheel, this is speculation on my part, so hopefully those with more experience will chime in. I'd like to see your grinder, what size wheel are you using? I'm about a mile from Big R (140&62) bring mikehr over with you and try out the KMG. Mark Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted June 24, 2009 Share Posted June 24, 2009 all the wheels have their own thing as to feel, but most work the same way. I only have a few contact wheels: 5/8" 2" 5" 8" and looking for a 1" and a 14" Quote Link to comment Share on other sites More sharing options...
Chosenfrozen Posted June 25, 2009 Share Posted June 25, 2009 (edited) I`m new to forging, but stock removal was my bread and butter (Literaly how I earned a living) for years. The smaller wheel creates a deeper dish in the blade and just makes it easier to find your groove again and again. 8" seems to pretty much standard, but I've known guys to use as big as 12" and as small as 4". It`s all personal preferance. Still, I find it easier and more relaxing to flat gind on a platen or a disk instead. Edited June 25, 2009 by mod07 typo Quote Link to comment Share on other sites More sharing options...
markb Posted June 26, 2009 Author Share Posted June 26, 2009 (edited) I did a few more practice grinds, comments, advise, criticisms encouraged. Not entirely sure what I'm doing. The little blade is ground on 10" wheel 36 grit. Thanks for looking. Mark Edited June 27, 2009 by mod07 photo thumb repair Quote Link to comment Share on other sites More sharing options...
