Grafvitnir Posted June 5, 2009 Share Posted June 5, 2009 Hi Someone gave me two cross pein hammers (3 and 4lbs) but they have fiberglass and jacketed fiberglass handles which are very uncomfortable to use. I would like to change them to wood but don't know the best way to do that. Has anyone done that? Thank you very much Rub Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 5, 2009 Share Posted June 5, 2009 Saw them off close to the head with a hacksaw and knock what's left out from the handle side with a punch and hammer. If I'm reworking the head I cut it off and burn it out in the wood stove. Frosty Quote Link to comment Share on other sites More sharing options...
jimbob Posted June 5, 2009 Share Posted June 5, 2009 after I cut the head off I drill it out with a 5/16-3/8 drill then use a punch to knock the rest out. Quote Link to comment Share on other sites More sharing options...
Bob JS Posted June 5, 2009 Share Posted June 5, 2009 Drill and punch works - just look out for all that fine fibreglass dust - a mask is highly reccomended. Although ideally you want to avoid contact with the stuff, if you rub talcum power into the skin on your hands and arms, it will fill the pores and help prevent irritation. It think switching to wood is a good move - I find the shock transfer of the fibreglass gives me wrist pain, I have had no trouble with wooden handles, touch wood! (sorry couldnt resist that) Quote Link to comment Share on other sites More sharing options...
Grafvitnir Posted June 5, 2009 Author Share Posted June 5, 2009 (edited) Thank you very much for your answers. I've never sawed through fiberglass before so I wasn't sure that was the way to go. In this case I'm not reshaping them so I wanted to avoid heat for removal to avoid having to retreat them (heat treatment). Thanks a lot again. Rub Edited June 5, 2009 by Grafvitnir Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 5, 2009 Share Posted June 5, 2009 Anything for a Heinlein fan. The fiberglass will dull drill bits, saw blades, etc. It's why I use a hack saw rather than my bandsaw. Bandsaw blades cost a LOT more. Frosty Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted June 6, 2009 Share Posted June 6, 2009 When you heat fiberglass or epoxies it gives off nasty smoke and fumes. With that in mind I warm the head with sawed off handle inside to about 385f in a toaster oven out doors. When it is ready the glass will push out easy. Quote Link to comment Share on other sites More sharing options...
