Dragonboy Posted March 24, 2006 Share Posted March 24, 2006 Is there any reason why a person should not use plywood in the construction of the top, bottom, and center boards rather than the lamanated board shown in both the blueprint on bellows? Quote Link to comment Share on other sites More sharing options...
Woody Posted June 2, 2006 Share Posted June 2, 2006 Dragonboy: The only reason for not using plywood would be for authenticity reasons. In the "good old days" they didn't have plywood. Other than that, if I had to make another set, plywood would be a definate consideration Woody Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 2, 2006 Share Posted June 2, 2006 I used a veneered plywood for a large double lunged bellows; I built it in around 1982 and used it---including leaving it outside over winter until I moved in 2004---I passed it on as it was getting a bit scruffy. Thomas Quote Link to comment Share on other sites More sharing options...
GobblerForge Posted June 7, 2006 Share Posted June 7, 2006 Plywood works perfect for bellows construction. Remember, you get what you pay for. Buy plywood with the best lamination and grade for your project. Right now, building material has skyrocketed. But for some reason, cabinet grade plywood hasn't rissen in comparison. As for Woody's coment on authenticity, I would agree that it is important to learn traditional in all aspects of your blacksmithing art. After all, you are learning an ancient craft. But we also must remember that they were not stupid back then either. If they had access to things like plywood, torches, power drills, electricity, running water, birth control and deoderant, they would have used it. I used 3/4" plywood for my bellows back in 91 and noggahide for the wrap. Still don't know how many noggas had to die to make that thing, but it works great still. Gobbler Quote Link to comment Share on other sites More sharing options...
