ichudov Posted March 23, 2009 Share Posted March 23, 2009 I have set up my 137 lbs Peter Wright on a stump in my backyard. Much higher resolution pictures are here:Peter Wright anvil In the last picture, I am showing some attachments, and the only thing I know is the cone mandrel. What are the other ones used for? Quote Link to comment Share on other sites More sharing options...
keykeeper Posted March 23, 2009 Share Posted March 23, 2009 Pictures are awful small, but the other "attachments" look like tinsmith stakes. They would better be used in a stake plate, I would think. Nice anvil, though. Quote Link to comment Share on other sites More sharing options...
TechnicusJoe Posted March 23, 2009 Share Posted March 23, 2009 Even though the pictures are small i think that didnt a welded steel plate on it so if its made out of steel i bet it has a nice ring and rebound!:D Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted March 23, 2009 Share Posted March 23, 2009 Well one is a candle stake, it is the long skinny one. They are nice for making small rings and tubes of thin sheet metal. It also looks like you got one that is all bent up or maybe I should say down for some reason. You also have what I believe is called a buck horn stake and it looks like a bigger version of the candle stake except that the horn part is much bigger like the horn of the anvil. These are buck horns a very nice for shaping compound curves for sculptures and such things but originally for sheet metal work. The flat stake looking thing may be a hatchet stake but I can't really tell from the picture. The good looking candle stake and the buck horn stake will sell for around $125 to $175 respectively. A better shot of each stake would help a lot. Quote Link to comment Share on other sites More sharing options...
ichudov Posted March 23, 2009 Author Share Posted March 23, 2009 Pictures are awful small, but the other "attachments" look like tinsmith stakes. They would better be used in a stake plate, I would think. Nice anvil, though. Go to the link on the first post, the pictures on my site are HUGE. Quote Link to comment Share on other sites More sharing options...
Jeff Bly Posted March 24, 2009 Share Posted March 24, 2009 How did you get the writing on the anvil to come out so clear? It almost looks sandblasted clean, unless it's been superbly preserved. Quote Link to comment Share on other sites More sharing options...
ichudov Posted March 24, 2009 Author Share Posted March 24, 2009 How did you get the writing on the anvil to come out so clear? It almost looks sandblasted clean, unless it's been superbly preserved. I wire brushed it with an angle grinder. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 24, 2009 Share Posted March 24, 2009 Blowhorn, needlecase and hatchet stakes, not designed for use with an anvil---pounding a wedge in a hole of a piece that was jumpwelded to the body of the anvil is not a good idea. Quote Link to comment Share on other sites More sharing options...
ichudov Posted March 24, 2009 Author Share Posted March 24, 2009 Well one is a candle stake, it is the long skinny one. They are nice for making small rings and tubes of thin sheet metal. It also looks like you got one that is all bent up or maybe I should say down for some reason. You also have what I believe is called a buck horn stake and it looks like a bigger version of the candle stake except that the horn part is much bigger like the horn of the anvil. These are buck horns a very nice for shaping compound curves for sculptures and such things but originally for sheet metal work. The flat stake looking thing may be a hatchet stake but I can't really tell from the picture. The good looking candle stake and the buck horn stake will sell for around $125 to $175 respectively. A better shot of each stake would help a lot. Hi Bentiron, Here's a very detailed picture with every piece numbered. Number "1" is an anvil, we all know this. Number 2 is a cone mandrel, I think. But what about other numbers? Here's the big picture: Quote Link to comment Share on other sites More sharing options...
ichudov Posted March 24, 2009 Author Share Posted March 24, 2009 (edited) After looking at the picture and other comments, here's how I interpret the items on this picture: 1 - Anvil 2 - Cone Mandrel 3 - ?? Hatchet Stake ?? 4 - Needlecase Stake, see Peddiman Needle Case Stake 5 - Blowhorn Stake, see ebay item 110360263619. These stakes were used by tinsmiths to shape tinware such as funnels and the sides of dish pans. 6 - Needlecase Stake Edited March 24, 2009 by ichudov Quote Link to comment Share on other sites More sharing options...
keykeeper Posted March 24, 2009 Share Posted March 24, 2009 I think you'll find Thomas P. knows his stuff, ichudov. Don't discount anything he says about smithing, equipment, or the like. The man is a walking encyclopedia of blacksmithing knowledge. I'd bet anyone would be hard pressed to picture a tool he doesn't know the name, use and history of. Quote Link to comment Share on other sites More sharing options...
