665 -
Posts posted by M.J.Lampert
was heated in advance but not enough advance in now for first cycle
thanks for the pointers Georgerge, Welshj, ThomasPower, and JHCC. I cleaned up the blade some more there are still two or three little pits but it definitely looks much better now quenched and waiting for oven to heat up
thanks tomas and frazer
if i do three smaller pieces in a bit of vinegar can i reuse it for a few more if I add a small amount of fresh
thanks before hand
M.J.Lampert
frosty i don't use website contact links unless there is no other way. Prefer to talk with an actual person not wait 1-5 days for each reply. I would take any rod under 3/8ths but i cant get any brass at all other than the $7 for 6 usable inches on a toilet float rod. might try melting and casting damaged brass rifle shells
sorry everyone had Wi-Fi problems so couldn't check on comments
On 11/12/2020 at 9:27 PM, GutRot said:Where are you at in BC? M.J.Lampert there are metal supermarkets in a couple places I see they sell brass rod pretty cheap
GutRot I tried all the metal suppliers around and 1 could get a 12 ft. 3/16 rod special ordered from Chicago for over $250
On 11/12/2020 at 9:46 PM, Irondragon ForgeClay Works said:I use no flux brass brazing rod for pins, easy to get in most auto parts or welding stores.
checked with the welding store haven't heard back
ThomasPowers and Irondragon ForgeClay Works yes I like the Arkansas toothpicks as well but as a dagger that's 5-15 years down the road i first came across them in a louis l'amour book I believe 'ride the river' (Sackett book # 5) and was like i need that and then i realized there's little use now days for suck a knife
plan to do more work today so maybe posting again today
5 hours ago, ThomasPowers said:
Are you going to sharpen the clip? Add a brass strip to the spine?
no the clip wont be sharpened as for a brass strip i can only find toilet float rod for pins have tried to get brass rod at a local supplier and they couldn't get any brass unless they special order it and then its to expensive. the guard will be mild steel
finished stretching out the steel to thickness between 0.16 and 0.17 the last 2 inches of stock are not to thickness and will be cut off next day when i trim the billet closer to size to shape
thanks every one for explaining. really helped
On 11/7/2020 at 1:24 PM, Bionic_Texan said:
Spring steel would be 5160 correct?
commonly a variety of 5160(+-15/20% carbon) but not always. the reason i said that thought is the thickness i looked and realized i made a typo i meant 7/16 which without proper technique is hard on you and your will power as well as using time that could be spent on a different knife
On 3/21/2017 at 12:37 PM, Frosty said:
Put a wire wheel or buff on a disk grinder and it's NO GLOVES PERIOD!
what? frosty my father taught me to wear gloves with a wire wheel a cut-off or grinding ok without gloves but welding gloves, safety glasses, face shield, long clothing + a pair of coveralls. O and if possible a piece of plywood between your guts and the wheel
just a word of advice dont try 5/16 spring steel until you have your hammer technique figured out, it takes forever (don't ask how i know) and it wastes a lot of propane
also DO YOUR RESEARCH i learned this the hard way, and i assure you you don't want to
born to smith, forced to work
ha ha Thomas power
random person asks smith "so do you shave just your for forearms or what."
smith "no that's just all am wiling to put in the flames"
i dont know how that would work try on your best pair and let me know
jlpservicesinc Frosty JHCC everyone else straight white vinegar put a few drops on a piece of paper towel and wipe on both lenses let dry and wola. I usually do it every day or 2 that i use the goggles though might be able to stretch it longer
for working they allow you to forge in a t-shirt and not burn your forearm with hot flakes and when reaching into dragons breath
daswulf I use Watson welding gloves they go half way to your elbow and come of easy as well as being decent cow hide
On 11/1/2016 at 7:57 PM, seldom (dick renker) said:
c-1 lets face it, "all good people are left handed".
the good lord made a few good people the rest are all right handed
On 11/25/2018 at 6:04 AM, jlpservicesinc said:
now wearing eye protection and then the fact that they fog make the job useless..
i do snowboarding and rub vinegar on the lenses to prevent lens fogging
i dont know about others but i just use you normal cowhide welding gloves from Watson gloves these are comfortable and have a Kevlar stitch. i don't usually use tongs as all i have is a pair of short reined farriers tongs but weld a 2-3 foot piece of mild steel on as a handle
On 10/23/2020 at 7:55 PM, ThomasPowers said:
Had a student try forging in crocs once; humorous to others; painful to himself!
i did that mistake one while welding wont do it again got a scar for my efforts
for me I've preferred steel toes boots protects your foot better if you drop heavy steel also leather is nicer as it doesn't light up from sparks, though a pair of dunlops works well in late fall, winter, and early spring after they get full of holes from sparks you put on some tuff toe from redwing shoes and get another few years out of them
bowie knife for school project
in Knife Making
Posted
and today.
the pins are brass, guard is 1"x1/8th mild steel tacked to blade as said before blade is leaf spring quenched in canola oil. 90% of finishing done with an angle grinder, handle (the last 10%) was done with a milling machine and orbital sander
had a few small fitting problems but figure after having my first 3 blades crack/shatter before I got close to starting handles, i can easily accept those few minor imperfections
