bubba682
Everything posted by bubba682
  1. I would v out the crack with a grinder to a bout a 1/2 '' both sides and deep as well.Then i would tack it on all four sides first the run pass's by goin oppisite sides one pass at a time so it doses'nt pull out of square and repeat this till its welded out.7018 is not the rod for cast , i think its a 152 cast rod i cant remember the brand name . You'll get out of using a pre and post heat it digs l;ike 6011 and use's the same heat.They work great on cast I would also sweat the crack out just enough to get the moisture out when your tackin about 200 degrees.
  2. I tightened alot of things up tonight and it took alot of the bounce out a few more alterations it should be tamed lol im goin to anchor it to the floor as well.
  3. I just built a hammer im getting alot of bounce i got it mounted to 4x4 and 3/4 plywood im wondering if you are getting bounce im thinking about putting anchor bolts into the floor how is your hammer mounted.
