Everything posted by Guiltyspark
A youtube series on tools needed to start a knife shop (must watch)
Im shocked these videos only have a few hundred views each. Spread the word , possibly give this a sticky. part 1 out of many. link removed Commercial add, plus usefull information has already been covered in the IFI knife chat.
Tips for making a good charcoal forge.
So I'm looking to build a charcoal forge. Specifically charcoal and not coal. I have heard there are differences in design between them. Like side blast instead of bottom blast. What are some tips and guidelines for a forge I can build for general blacksmithing and knife smithing.
Carving out cylinders for hidden/partial tangs.
What epoxy do you use? I have this milliput stuff that is pretty popular in the scale model community. Not sure if i should run out for a better alternative.
Need information on "knife sculpting"
Yes i read the stickies and own all of the J hrisoulas books as well as nearly all of the other knifemaking books in print. As for being all over the place I dont see why that is a problem. I like to gather as much information as possible on processes im using and processes i might use in the future. Its how I learn things. I dont like your attitude for a moderator BTW. Telling new posters they "wonder why nobody answers you anymore" is frankly pretty rude and stuck up. If I were spamming the forum with nonsense like "how du i mayk nife?" that would be one thing but im not. Im asking specific questions about specific processes that are not covered in any of the stickies or knifemaking classes (that just started BTW).
that is completely and utterly ingenious. I am literally speechless right now. My workload just went from nightmare to XXXXXXXXX , thank you SOOO much.
What are the best ways to do this? It seems so easy going into it then you realize that its not easy at all. My harbor freight drill seems to "bend" out of alignment when pressure is applied , and i dont think my needle files are doing very good job of squaring up the hole. What are the best techniques to do this or am I doing it right but it just takes a long time?
Can anybody recommend me some good flex shaft motor tools for this purpose? I have a battery powered dremel and its a nightmare :(
totally agree but I'm not sure where the best place to buy it from to make sure he gets the money and not a third party. And I'm asking for more resources because more is better
wait never mind it's there in another post. Any more stuff
no that's not what I'm talking about
http://www.amazon.com/Sculpting-David-Broadwell-Techniques-Texturing/dp/B001II9YH8 I found this DVD online and was incredibly interested in this process but can find no information online about it. Are there resources that I don't know about that cover this technique ?
Knife grinders?
Right now I'm having trouble putting a good consistent edge on my knives. And shaping them is becoming a chore with my equipment. Right now the only real power tools I'm using are a cheap 7 inch angle grinder and a Ryobi belt sander flipped upside down. I'm worried about both because they are sloppy and really heat up the metal. Can somebody explain to me what I need to invest in if I want to start making edges that are good enough to sell? I have seen these multi wheel belt sanders but it seems like it would be too expensive. Am I wrong? Could these be made cheaply . Like under 500 dollars? I did see a buffer/knife grinder combo from grizzly that looks like a Kalamazoo. What is the difference between a two wheel system and a 3 or 4 wheel system? Or is all I really need a wet wheel grinder?
If I was to sell a set of cooking knives for production. What 3 would be best
That would be great if you could send me info
Thanks. Any guidelines for price or how I should determine price with materials vs labor? Also I know that filet knives are thinner. What flat stock should I use?
I know a general chef knife but what else? I'm selling them in a block. If 3 is too little what number of knives would be sufficient ?
How do i add doors to this forge?
what is a blown forge?
no i dont weld :( i hoping to change that soon with classes. I have welded once and found it complicated (stick welding) and it was tricky because the rod always got stuck on the work.
http://i.ebayimg.com/t/New-2-Burner-LP-Propane-Gas-Forge-Knifemaking-Welding-Blacksmith-/00/$(KGrHqEOKpwE4kVYPpIJBOMHyG3f4Q~~0_12.JPG I dont really have a stand for this forge that would let me use bricks as doors . I guess i would rather have a built in door and i already ordered kao wool for it. How do i make this work? are there plans on how to do this?
M.C. silver-steel razor
i really want to make a razor , how do you forge this? do you forge it as a rectangle or a wedge and than hollow grind?
I have one of those ebay "knifemaker" 2 burner forges , Do i have to cover the back?
Is there a guide to getting a gas forge running right
Techniques for straightening knifes?
I am having major trouble straightening. Blades. I think my blades slowly warp after I check for straightness after correcting a flaw. When doing full tang blades it seems like this is an impossible task to level the tang out. I don't know if I haveremoved too much material or if I am bending it too far or not enough. Please list all the techniques you use to straighten your blades as I am lost to the process
My third knife (second nice one)
USA knifemaker orange black
thanks its a little paring knife , im making a matching chefs knife with the same scales
My first forged blade ready for heat treat
make sure your anvil is perfectly level with your waist , that when you lay your hammer on the anvil on its face , your forarm is level.
Lack of skill? or impatience ?
hmm thats not it then.... when i grind a knife it looks great , but i have to grind ALOT and i feel like im wasting steel when i do it. Like the worst thing for me right now is when i do the handle , the surface is never flat and its almost impossible to fix enough to get the scales on. so i have to grind the upset edges because they are so raised up and uneven. I see these videos and people are making these clean forgings that look almost arrow straight , im thinking it has to do with my anvil or something.
