This is a truck axle and hub, cut the axle to form a hardy post. Grind the lugs to a round top. Make a centre pin guide and fit on a hot blank. depress the centre and get a lilly pad candle pan big enough for Jeremy to sit on. (dancing Frog)
IForgeIron Blueprints
Copyright 2002 - 2011 IFORGEIRON, All rights reserved
BP0395 Easy Punches
by sfDuck I just happened to have a few butchers steels hanging around and suddenly the light bulb turned on. They were cast steel, hardened and able to sharpen stainless. If you removed the handles and tangs they would make nice extra long punches. That Easy. Rework the ends and they could become any shape you could imagine. And can pick more up cheap at the local flea market.
View full article
I got this blade in another trade and when my daugher saw it she claimed it for wearing at camp. All I had to do was put a handle on it. So a brass guard a couple of spacers and some moose antler later, Oh, then she said so wheres the case Dad. Thats a penny on the handle to show the size
This is another kit knike, making the handle is the hardest part for this knife. Finishing up all the parts in the kit is just a matter of fitting sanding and polishing.
Theses turn out pretty good and give you practise for when you make it all yourself. Just try to remanufacture your own parts and before you know it your making your own.
This is the other Solengen blade blank I got. This time I used sheet silver to line the ivory and filed the edge a little, and brass to make the bolster. Again brass pins.
This is one of the blank Solengen Blades I got in a trade. All I had to do was clean it up a bit and polish it. The ivory is Walrus tooth and has a silver spacer that is file worked and pinned with brass.The bolster is brass shaped to the blank.
Scein Duie or black knife was taken from its hiding place on the body and stuck in the top of the stocking so it would show and tell your good intentions.
Traditional bollick handle of blackwood, german silver fittings, and orange glass. Blade is from a nickolson file with rope filework down the back and bottom of rockasso. File marks left on to show it was from good steel. Case G silver and leather.
This is part of a collection of knives that I made a couple of years back and have come back to roast. Some are totally my make and some are kits that I put together and two are german blade blanks that I got in a trade.
Steel blade, guard,file worked spacers,blackwood handle, with silver wire inlay, steel pomel. Sheath is leather covered wood with german silver fittings
