Hey everyone,
First time blacksmith in Winnipeg (Canada) here, and I'm trying to set up my own shop. I'm about halfway through building a gasser and I've got the tools I need to make the rest of my tools. I just got an old piece of rusted railtrack. I took the grinder to the top face, but it was rounded AND had metal delamination in most corners, so that wouldn't work.
I then took the grinder to the bottom and found it fairly flat, but really pitted. The surface is 12in x 6in in size. After having taken the rust and most high spots off, I started drawfiling it to see what it would give. The result is pretty smooth, but I'd have to keep at it through probably another 5-6 movies to get all of the pits out. Or I might just go to town with the grinder and then just even things up with the file...
Here come the questions:
1- The rail will fit in my forge (barely), so the plan was to heat it to bright red then put it in a barrel of water and move it up and down to get it to harden. After this I'd bake it in the oven at 330*F for about an hour. Is there something that's wrong/could be better with this heat treatment?. (I don't know the exact makeup, but the sparks were exploding enough that I think it is hardenable.)
2- Because it's a rail bottom, there isn't a solid mass of metal under most of the striking surface. Plan is to put the rail in a pail full of cement and sink it until the cement is a bit higher than level with the lower edge of the striking surface. Would this put enough mass underneath, keeping in mind that I'm a complete beginner?
3- Because the metal is thin on the edges (1cm), I'm thinking a backing like I mentioned in Q2 would be pretty much required no matter what I do. Opinions?
I've got something that can be used as a mandrel, so I don't really need a horn, and I plan on making a separate hardy holder (and perhaps sinking it in the same bucket. Maybe it's just a quick, but I like to keep things modular.
My computer decided that it didn't like my camera, so I'll upload the pics from another computer in a few hours.
Thanks,
Toreus
Edit: it gives me an internal server error when I try to upload pics, will try again soon
