First try with cable
GottMitUns
One of my oilfield customers brought me some 3/4" wire rope and I finally worked my nerve up to try and forge weld it.  After 2 years of heating and beating and reading this sight pretty much daily I must say making the billet was easier that I expected and that doesn't happen very often.:D
One observation I can make is 1 linear inch of 3/4" cable does not make near as much solid billet as it looks like it will!
I forge a billet from cable appx  1/2"x1/4"x12",
cut it into 3 pieces,
sanded, stacked, tacked, fluxed, forge welded,
and forges back to 1/2" x 1/4" x 12"
I repeated this process again, only I turned the billet 90Dgr. after forge welding it and drew it out to appx 1"x 1/4" x 5".  At that point I thought I might want to try and make a knife out of this.
7-5-15_006.thumb.JPG.115e3b07e347c55d334
7-5-15_004.thumb.JPG.05f35cb875f455727e5
I free hand filed it into shape and sanded it down from 80 grit to 600 grit while it as in a annealed state.
I etched it in a solution of hot vinegar and salt (thank you ThomasPowers) for 18hrs
I brought it above non magnetic temp and let it air cool to black heat 3 times then quenched it in ATF.
I heated the spine until the colors ran to blue on the cutting edge, then buffed it with a Scotchbrite belt on a belt sander
The waves on the cutting edge came from me being careless with tongs during the heat treating process
Thanks IFI
Russell
