May 14, 201313 yr Thank you for the tutorial, clear and easily understood. Well done Frosty The Lucky.
May 14, 201313 yr Awesome! Thank you for the tutorial! I'm in the process of doing some right now. I'm working with a diamond shape. The way I registered it was to put an outline on the paper around my image. Then I tape the image to the copper and using my stomp shear, I cut to the outline. I didn't pre heat the copper so indexing was pretty easy. The paper was the exact size of the copper... The one thing I would add is using a thin cotton sheet over the paper. It will help the iron move around on the paper easier.
May 15, 201313 yr Author This is a brass plate I did tonight. This one you can see how nice and clear lettering can come out with this process. Pound Hound
