Can you forge Aluminum i.e. with a hammer and anvil? Is there any toxic gasses or anything that I should be worried about?
Forging Aluminum?
Started by metalworker77, May 14 2007 08:43 PM
7 replies to this topic
#1
Posted 14 May 2007 - 08:43 PM
#2
Posted 14 May 2007 - 08:51 PM
aluminum melts at so low a temperature (I am not sure but I think around 1350 degrees F, not even red heat for iron/steel) that you'd be far better off casting it. A good site for that is backyardmetalcasting.com
good luck!
Archie
good luck!
Archie
#3
Posted 14 May 2007 - 09:07 PM
Soft aluminum not the T-6 or other hard kinds can indeed be forged with forge and anvil. IUse common precautions such as not breathing either fumes from forging or from the forge. You have to play a bit to find the right temp to forge. Try this in a gasser put the piece in and count to 15 take it out and rub a hickory hammer handle on it..if it does not leave a mark go back in for ten count. If at any time the hammer handle leaves a dark browm mark really fast stop and let it cool. coutn to 20 and try the wood again should be a nice brown mark but not dark...then forge away..You can froge for quite a whiel before you need another heat for next heat put piece in and count to 10 check with handle etc.....have fun
#4
Posted 14 May 2007 - 09:17 PM
Forging aluminum is very common in industry, and occasionally done by artist/blacksmiths. I have only played with it once in the forge, but it wasn't a big deal. Like everything else, you have to learn your material.
Some links for this topic:
http://www.artmetal....ssages/374.html
Aluminum Chart
Aluminum forgings from Scot Forge
Forging non-ferrous metals
Forging of Aluminum Alloys
Wendell August Forge's hand-hammered aluminum carries on 77-year tradition
Aluminum Chart
#5
Posted 14 May 2007 - 09:30 PM
wow, I never knew it was actually forgeable! cool! You learn somethign new every day.
#6
Posted 14 May 2007 - 10:51 PM
Aluminum can be cold forged easily, there is usually no need to heat it. I am of course talking about plate aluminum. It will get brittle when over worked, but with a bit of care, you can do a lot with it.
Joseff
Joseff
#7
Posted 14 May 2007 - 11:43 PM
I forge aluminum all the time I use the same methods as Rich Hale has described. If you take your eye off it for a second it will melt on you.
#8
Posted 15 May 2007 - 02:05 PM
Dad always said that in order to torch weld or forge aluminum, 1st you buy 3 pieces-because you will burn up the first two learning when to stop heating.
\"getting old aint for sissies\"
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
