Iron Falcon 72 Posted February 21, 2009 Share Posted February 21, 2009 Here's a couple of photos of a dredge tooth that I figured would make a nice hardy cut-off. Regrind the top to get one flat side, one beveled and a square edge instead of the worn rounded tip. Weld a bar across the base with a hardy mount welded to it. It should be fairly hard steel although it may react adversely to heat. It's about 7" tall. What do y'all think? Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 22, 2009 Share Posted February 22, 2009 Bucket teeth are typically high manganese impact resistant so don't preheat it to weld. Maybe see if the welding store near you will sell you a few sticks of high manganese rod though 7018 should be okay. Otherwise it should work just fine. Frosty Quote Link to comment Share on other sites More sharing options...
