I Need Forge Help
Okay I am going to tire to build a forge out of about 100 center blocks or bricks and 5-6 metal Barrels. Now I need some plans if you can help. :D
You will burn coal?
Yes were the Forge will be place it will be to hard to bring gas to.
Edited by Welund Smith
Have you looked through the "getting started" and blue prints" section of IFI? There are a number of forge designs to be perused and adapted to your needs.
Glenn's 55 forge is a proven performer and there are lots of pictures of masonry forges including a series of progress pics of a beautiful brick forge built by Irnsrgn. Try little searching IFI a little.
Then again by time you check back there'll probably be a bunch of suggestions, links and such to choose from..
Frosty
Frosty
I seen the 55 but I need detail plans and such
