leroyk Posted January 11, 2009 Share Posted January 11, 2009 Hey Fellas I am looking for either a 6 in or 8 in hydraluic cylinder with 6 or 8 in stroke. If anyone knows of one, please email me at [email protected] or post on here with price leroy Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted January 12, 2009 Share Posted January 12, 2009 Just go to a tractor supply or farm supply place and get a prince tie rod cylinder, remove the bolts, and cut it to length in a bandsaw, chamfer the cut edges, use shorter bolts and cut the ram to length. Off the shelf is going to be cheaper than custom built. Quote Link to comment Share on other sites More sharing options...
leroyk Posted January 12, 2009 Author Share Posted January 12, 2009 I guess what i meant was a 6 or 8 in diamiter cyl leroy Quote Link to comment Share on other sites More sharing options...
LarryM Posted January 13, 2009 Share Posted January 13, 2009 Just go to a tractor supply or farm supply place and get a prince tie rod cylinder, remove the bolts, and cut it to length in a bandsaw, chamfer the cut edges, use shorter bolts and cut the ram to length. Off the shelf is going to be cheaper than custom built. irnsrgn, Is right on the cylinder. I'd try to buy new what I'm looking for, there's less hassle. If you need it a certain length do like irnsrgn says shorten longer cylinder. Question what are you using cylinder for? If you are building a hydraulic press. Do the math for an 8" diameter cylinder using 2500 psi power unit. It figures out to be almost 63 tons. That's big press. Quote Link to comment Share on other sites More sharing options...
leroyk Posted January 13, 2009 Author Share Posted January 13, 2009 i an ging to build a press but my pump only puts out 1500 psi. Maybe a 6 in would be large enough but if i build it i want to be sure to have enouower lee Quote Link to comment Share on other sites More sharing options...
mindovermetal Posted January 13, 2009 Share Posted January 13, 2009 try Burden Sales Surplus Center - Hydraulics, Engines, Electrical and More they have new rams of all sizes Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted January 28, 2009 Share Posted January 28, 2009 what would be a good working pressure/ tons for using a ram for drawing out steel, sort of like a power hammer? and is it a feasible way to do that? thanks. Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted January 28, 2009 Share Posted January 28, 2009 and how many gpm would you reccomend for doing that, thanks kind of kicking around this idea, any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
