champion speed controler
Does anyone know where I can get a replacement for a champion fan motor controller. The controller has a ceramic plate inside that has points where the handle slides across for speed control. This ceramic plate is what I need to replace. After talking with several suppliers the cost of a new speed controller is 200.00 for 230 volt motor.
Eddie
I have a Champion speed control somewhere in the shop and once looked inside. As far as I can tell, not being an engineer, it looks like a rheostat. My advice is to go to a company that sells motors and motor controllers and inquire about a rheostat that matches your motor. Maybe they will even have an appropriate rheostat that will also fit inside the Champion metal housing.
There are always a few "new old stock" Ohmite ceramic rheostats on Ebay that usually go fairly cheap. That is what I run on my Buffalo 2E blower. I bought a 150 watt model L.
You can also use a common light dimmer switch or fan speed control, however you will have to replace them every year or so. At least that has been my experience.
Edit: I just reread your post and noticed the 230 volt comment. If your motor is 230 volt, I have no experience with 230 volt speed controllers. My comments apply to 110 volt universal type motors only.
Edited by BT
addl. info
Dimmer switches that can take 1000 watts are available in the UK for 240 volts
