Greg C. Posted November 10, 2008 Share Posted November 10, 2008 I was thinking using a drill to make the cut, but then it would be limited to the size of the bit. Let me know, Chuck Quote Link to comment Share on other sites More sharing options...
highlander Posted November 10, 2008 Share Posted November 10, 2008 make it to fit in 2 halves and glue them together Quote Link to comment Share on other sites More sharing options...
Robert Mayo Posted November 10, 2008 Share Posted November 10, 2008 Start with two pieces of wood, trace your blade on both of them then chisel,carve out half the thickness of your blade from each one. I glue and pin them together then mark your blade on the outside, trim and form to the desired shape. Bob Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted November 10, 2008 Share Posted November 10, 2008 I use a forstner bit to clean out the bulk of the wood then clean it up with a chisel. Quote Link to comment Share on other sites More sharing options...
Woody Posted November 11, 2008 Share Posted November 11, 2008 A nice touch is to cut the blade shape deeper than necessary and then line the sheath with leather before gluing the two halves together. Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted November 11, 2008 Share Posted November 11, 2008 Another neat touch is line the throat with a piece of velvet that has a pretty stiff nap. It will help retain the knife in the sheath. Quote Link to comment Share on other sites More sharing options...
