tanglediver Posted December 17, 2023 Share Posted December 17, 2023 Someone here asked me today after my afternoon session, "What, are you a blacksmith now?" Well, no. I am not, and I said as much. The ever-so-humble drum forge, my first. Long story made as short as possible, after finding an identical blower (finally), I whipped up a cheezy stand "for testing purposes". It operates, I can heat metal, and I call that "a start". Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 17, 2023 Share Posted December 17, 2023 Might I make a suggestion, pack some clay around the fire grate to make a ducks nest fire pot, which will save on using so much fuel and give you a hotter fire by concentrating the air blast. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
tanglediver Posted December 17, 2023 Author Share Posted December 17, 2023 Did I mention I've been using wood as fuel? This won't be my final solution for a forge. As I say, it has gotten me started. Neither did I post in an appropriate location. Thank you _ for your direction. Quote Link to comment Share on other sites More sharing options...
Nobody Special Posted December 17, 2023 Share Posted December 17, 2023 It's a good start. If you've got wood, it's not terribly hard to make lump charcoal if you have a 55 gallon drum and a place you can make fire without the neighbors freaking out. You may also find that you prefer a brake disc, or if you are going to eventually be using charcoal (coal being a bit tricky in California), the JABOD forge (just a box of dirt). Welcome, and best of luck. Quote Link to comment Share on other sites More sharing options...
Michael Posted December 18, 2023 Share Posted December 18, 2023 That's a very nice start you have there! Lump charcoal, not briquette's works really well, you just have to use a small watering can to keep the fire from spreading too fast. Rather than claying the bottom, I found a couple of firebricks with the corners cut off, so they fit the round drum, goes a long way towards having the fire deep enough. a brick on each side of the drum with a deep trough between them. Masonry disks in an angle grinder make short work of it. my first forge pic attached. Quote Link to comment Share on other sites More sharing options...
