Avadon Posted September 19, 2008 Share Posted September 19, 2008 It dawned on me a few days ago that because I live near a state park that allows campfires (and their are always campfires going) that I might be able to go get coal from their campfires after they are burned out and they've left. Is this worthwhile or would the wood/coal be totally spent? Quote Link to comment Share on other sites More sharing options...
inazuma_x Posted September 19, 2008 Share Posted September 19, 2008 spent charcoal = ash i believe so anything that isnt ash should still be combustable... Quote Link to comment Share on other sites More sharing options...
ironrosefarms Posted September 19, 2008 Share Posted September 19, 2008 If you do this in a clean fashion (not leaving or scattering any trash) I would think you will find yourself not only a source of fuel but will likely find park employees who will be quite kind and generous. Our scouts volunteer to help the workers out twice a year to clean out the fire pits in each campsite (386 sites). Our keeping the employees from having to do this job has brought a good relationship with the workers and they have been very generous to our troop. I'm just ashamed that I didn't think about the use of the charcoal that is sometimes left... Thanks for the great idea! James Quote Link to comment Share on other sites More sharing options...
Avadon Posted September 19, 2008 Author Share Posted September 19, 2008 Well I got the idea from someone saying that if you don't have a drum to burn wood into charcoal you can alway make a fire and when the wood is glowing you can bury the combustable material and it will vent it's gasses and basically leave you with a decent amount of goal left over. Probably not the most efficient way of making charocoal but that is essentially what I think happens to most peoples firepits, when they try to bury the fire at the end of the night or when they use water to put it out prematurely. At 7$ a bag for charcoal.. might not be such a bad idea to scavage some campsights. I'll let you know if I have any luck with this method. I also have ton of wood to burn up come burning season. I often wonder if a lot of people burn their wood into charcoal at night as to draw less attention from the smoke? Quote Link to comment Share on other sites More sharing options...
