BlackCrowMetalsmith Posted September 14, 2008 Share Posted September 14, 2008 Should the shank that goes in the hardie hole be carbon steel, or will mild steel do? I've got a 2" axle that I'm thinking about cutting to make the shapes I want, and then welding a piece of square bar to the bottom of each. Also, if my hardie hole is 1", should I use 7/8" bar, or get 1" bar and trim it just a little...my anvil didn't come with any tooling, and I'm unsure of how tight the fit should be. Thanks! Quote Link to comment Share on other sites More sharing options...
fat pete Posted September 14, 2008 Share Posted September 14, 2008 I think if its too tight you may have trouble puttin it in or pulling it out....but i would get it pretty close Quote Link to comment Share on other sites More sharing options...
Finnr Posted September 14, 2008 Share Posted September 14, 2008 I use what ever I have on hand. A lot of my tooling is axle shafting I found on the place here when I was clearing off the trash left behind by former residents. I just use the shaft for the whole thing. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted September 14, 2008 Share Posted September 14, 2008 (edited) I don't think there is any reason the shank needs to be anything special. It's only job is to hold the hardy tool in place. The shoulders of the hardy tool around the shank take the shock of use. I've seen folks use square tubing for shanks. As far as fit.... A hardy should be EASY to put in and take out by hand (a little play). Edited September 14, 2008 by djhammerd Quote Link to comment Share on other sites More sharing options...
racer3j Posted September 14, 2008 Share Posted September 14, 2008 If the shank is a tight fit you are setting up the possibility of saying goodbye to your anvil heel. The shoulder is the key. Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 14, 2008 Share Posted September 14, 2008 Its all been said. Make sure its easy to fit and get out so a bit of slop is good but not too much or lining it up on your work gets harder. As for material, if you can get an old axle or torsion bar make the whole thing out of this, especially if you got it for a good price :) Quote Link to comment Share on other sites More sharing options...
