pagas Posted June 24, 2023 Share Posted June 24, 2023 Hello from Estonia , i managed to find old Hesselman hand crank blower and good thick old fire pot ,so question is how to i connect them in a way that oiling cap stay up position ,and what kind of frame/hood fabrication i should use any info about blower maker and fire pot would be appreciated also Quote Link to comment Share on other sites More sharing options...
George N. M. Posted June 24, 2023 Share Posted June 24, 2023 Welcome aboard from 7500 feet (2284 meters) in SE Wyoming, USA. Glad to have you. I assume that by "firepot" you mean the central part of the forge which holds the fire. In English, this is often called "the duck's nest." You may want to look at the threads regarding JABOD (Just A Box Of Dirt) forges. You may be able to modify something like that to install your firepot. Jabod forges are cheap and easy. I'm not sure about your question regarding the oiler. I assume that it is part of the blower. Pictures would help. Is it a hand crank blower or one with a motor? You generally don't need a constant oil feed on a hand crank blower. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
pagas Posted June 24, 2023 Author Share Posted June 24, 2023 box of dirt i have used with old style barrel bellows ,conical metal pipe acting as a side blast turey Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 24, 2023 Share Posted June 24, 2023 Welcome to posting from the Ozark mountains. That looks like a real beast of a blower, first time I have seen one. It should supply plenty of air for sure. We won't remember your location hence the suggestion to edit your profile and add it there. I just did a search as suggested in the Read This First thread and was amazed that there were no threads listed. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
pagas Posted June 24, 2023 Author Share Posted June 24, 2023 i have couple of treadle forges that i cleaned up and use, but the hand crank blower and so big fire pot i come across first time , so there i get the idea put them together and maybe even ad side draft hood into a mix I have been lurking in dark corner of the forum for couple of years ,and read up the old topics there are just so much knowledge to accumulate and shift through Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 25, 2023 Share Posted June 25, 2023 Glad you delurked Pagas, Pleased to make your acquaintance. I can't really see the fire pot well enough to make suggestions but the output side of the blower is pretty standard. A length of flexible ducting is what works for most folks that don't have blowers and forges with matching connector. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
pagas Posted June 25, 2023 Author Share Posted June 25, 2023 if i put ruler across the firepot it measure abtoximatly 45 cm ,and the pot is 12 cm thick, the curved depresion is 8 cm and the opening with clinker breaker is 6 cm , overall height of the fire pot and the clinkerbreaker system is 35 cm the air pipes in blower and firepot ar similar size 8,5 cm Any and all suggestion what kind of frame i should build for the forge would be appreciated And is there forge building topics i should read, that contain frame fabrication?? Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 26, 2023 Share Posted June 26, 2023 It should just be a matter of making a stand and hooking them up. Try looking in the solid fuel forge section of the forum https://www.iforgeiron.com/forum/64-solid-fuel-forges/ I don't know if there's much about building stands but there are lots of pictures and you should get some ideas. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
