Nail Header
Hi Guys,
Does anyone know where I can buy or how to make a nail header for 1/4" square nails?
Tom Clark from the Ozsark School of Blacksmithing sells them, and Rob Gunter also sells them. I think both have a web presence and you can contact them online... use your favorite search engine:-)
I found Rob Gunter, but couldn't find where he had anything for sale and Ozark School sells round nail headers. I'll take that if I have to, but I'd rather have a square one. Thank you much for the info though.
Levi the header my be round, but the hole is square and the size is what round stock you start with.
Hello,
Welcome to the forum!
I made a header for round nails. I started with a 3/8" thick piece of steel, and driller round holes in it for the size of nails I wanted. Then I took round tapers that I used to taper the "bottom" side of the holes to give them clearance leaving just the "top" of the hole to form the head with. I asked the same question once and this is what the guys told me to do
Here is a blueprint from Iforge over on the anvilfire site, of a little more fancy one.
Link removed at the request of Jock at Anvilfire
I went back and looked at those. You're right, the holes ARE square. Looks like these are what I'm looking for. Also, I knew about the plans for a header on Anvilfire, but the thing that keeps me from building that one is the $62 + shipping I would have to spend to order a square punch. Thans for the info,guys. I think you've gotten me what I need.
Levi: I made a square drift out of some rebar. I drilled a hole in a piece of 1/4x1" and drifted the hole to just about the size that most of my nails are. Nice thng about the drift is that it is tapered and makes the bottom hole larger than the top hole (like in the anvilfire demo). I think the 2' piece of 1/4" rebar cost about $1 and the 1/4" strip was a piece of scrap.
If you can make a nail you can make the drift. If you can use a drill press and drive a nail, you can make the header tool.
Good luck!!
Doug Merkel who is usually at Quad State makes & sells a nice nail header.
