Brax Posted January 8, 2023 Share Posted January 8, 2023 I bit off a bit more than I can chew and jumped into a double burner hero 2 Mr volcano forge as my first forge. I tend to only use 1 of the burners as I do not do that many projects that reach all the way to the second burner and it saves fuel as well. Should I take the second burner out of the forge when it's not running? If so 2 questions come to mind. 1. Is it safe to have it dangling there as long as the ball valve is off? 2. Do I need to close off that hole that the burner would go into ? Thanks Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted January 8, 2023 Share Posted January 8, 2023 6 hours ago, Brax said: Should I take the second burner out of the forge when it's not running? If so 2 questions come to mind. 1. Is it safe to have it dangling there as long as the ball valve is off? 2. Do I need to close off that hole that the burner would go into ? So long as the burner's air openings are kept closed, it should be okay. But double check the fuel hose to that burner, to insure it isn't heating up, do to the lack of cold incoming propane vapor to cool it down; if its hose is heating up too much to touch, it is safer to remove that hose, to keep it from overheating. As to the burner itself; so long as its air openings are kept closed by the sliding choke, the burner shouldn't overheat on these particular forges, because their burner port tubes are very close to the burner's mixing tube diameter. So, there shouldn't be any overheating from chimney effect. You can further protect a shutdown burner be adding an internal baffle wall, to separate that half of the forge from the area you need to heat; this will also greatly increase fuel efficiency. Quote Link to comment Share on other sites More sharing options...
Brax Posted January 8, 2023 Author Share Posted January 8, 2023 Thank you, that is a wealth of knowledge and lots of great information. As for an internal baffle would a properly cut firebrick work? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 8, 2023 Share Posted January 8, 2023 Welcome from the Ozark mountains. A cut IFB (insulating Fire Brick) will work as long as it is rated for forge temperatures and it's coated with something like Plistix 900F. Morgan K26 bricks usually are the ones recommended. There is a pretty good thread about the Mr. Volcano forge here. https://www.iforgeiron.com/topic/69760-mr-volcano-video/ Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted January 9, 2023 Share Posted January 9, 2023 Those are perfectly good answers. Simple hard firebricks are 2" wide, providing lots of stability, when used as an internal baffle wall. Quote Link to comment Share on other sites More sharing options...
