April 21, 20224 yr A delightful little video about a foot-powered cam hammer, probably for peening scythes.
April 21, 20224 yr I think the rod he was wondering about is a brake, may be missing the shoe. When he pulled the lever it slides the rod up a slight ramp so it will contact the hub.
April 21, 20224 yr Author Someone suggested in one of the comments that it might be an adjustable support for the snath.
April 21, 20224 yr It wouldn't be a brake, you can the treadle mechanism and wheel, with your foot just like a spinning wheel with that treadle to crank mechanism. I don't think the folding leaver thingy is a snath support it's too fragile and if the hammer is for peening scythes I'd bet the operator laid the snath on something behind him/er or maybe in the crook of an arm or over a shoulder. That way the edge would be facing him/er and more clearly visible. The ball on the end does speak for a female connection to something, I just can't see it being a brake, even a parking brake. The ONLY thing I'm sure about that folding leaver thingy is it was a significant part of the machine missing the business end. <sigh> I'd sure like to know what attachments were kept in the box. Frosty The Lucky.
April 21, 20224 yr Author It's interesting that each joint of the folding lever appears to have a toggle to lock it in the straight position.
April 21, 20224 yr Yes and stops so they won't fold the other way. I THINK. Knowing what other anvil dies and hammers were used in it might explain it. At 3:59 in the video is a clear view of the band and set screw holding the hammer handle. Frosty The Lucky.
