natkova Posted February 6, 2022 Share Posted February 6, 2022 Who saw my wood stove forge its.gone now iam trying to build forge that look like its not improvised from something. And here it is. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 6, 2022 Author Share Posted February 6, 2022 I have some issues with fuel geting clogged up where T mees it is 2 inches i dont know is tha small diameter Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 6, 2022 Share Posted February 6, 2022 Looks like the horizontal air supply pipe is sloping up towards the T. Try raising it so it slopes downwards to the T so ash, clinker and stuff doesn't catch so easily. If that doesn't work, put the air grate so no openings are directly above where the horizontal pipe connects with the T. I make mine from truck exhaust pipe which is larger and smooth inside. Stuff doesn't get caught in it. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 6, 2022 Author Share Posted February 6, 2022 6 minutes ago, Frosty said: Well i put air gate on it so it is not seen in pictures but it get cloged on where horizontal air pipe meet vertical one at T .. I tought diameter might be too small but i doubt it is about that. there is even plenty space for ash to go to bottom up to ash dump where i made it. It will be bad to ruin this all and convert it to side blast becasue i make fancy ash dump Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 6, 2022 Share Posted February 6, 2022 Where the horizontal and vertical meet is where they usually get clogged. If the horizontal is leaning away from the vertical then the bottom edge is farther out into the vertical than the top edge so junk can catch on it. If the horizontal is leaning towards the vertical (Blower end is higher) then the top edge is farther out in the vertical pipe and shielding the bottom lip from falling junk. I made the suggestion about not putting any openings in the air grate directly above the side of the vertical pipe the horizontal enters so junk doesn't fall even close to it. The idea is to direct ash, clinker, embers, etc. to fall past the horizontal air pipe with a centimeter or so space. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 6, 2022 Author Share Posted February 6, 2022 Well it is practicaly T shaped joint and then all horizontal and vertical welded in to it. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 7, 2022 Author Share Posted February 7, 2022 Well aded some rods that meet like X and it made it litle bit more stabilised. Now have issue from where air blows to oriantate but i think this will be good forge. I noticed now i have more place to heat steal like 4 inches i know i cant work on all of that at same time, but give you good courage that you did good job. Maybe some litle finish up at ashdumper as i feel sparks goes from there even lid is not closed small gaps probably air can leak there too couple welds will fix that. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 10, 2022 Author Share Posted February 10, 2022 On 2/6/2022 at 11:11 PM, Frosty said: Where the horizontal and vertical meet is where they usually get clogged. If the horizontal is leaning away from the vertical then the bottom edge is farther out into the vertical than the top edge so junk can catch on it. If the horizontal is leaning towards the vertical (Blower end is higher) then the top edge is farther out in the vertical pipe and shielding the bottom lip from falling junk. I made the suggestion about not putting any openings in the air grate directly above the side of the vertical pipe the horizontal enters so junk doesn't fall even close to it. The idea is to direct ash, clinker, embers, etc. to fall past the horizontal air pipe with a centimeter or so space. Frosty The Lucky. I noticed that i have better draft with bottom blast . What are other advantages of bottom blast forge. Now smoke goes up to chimney faster i think. Quote Link to comment Share on other sites More sharing options...
