Johnnie C. Posted August 18, 2008 Share Posted August 18, 2008 This is my first split cross I have made after about 5 atemps. Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted August 18, 2008 Share Posted August 18, 2008 Good job! looks nice. Quote Link to comment Share on other sites More sharing options...
triw Posted August 18, 2008 Share Posted August 18, 2008 Good job. One suggestion is if you use the sharp edge of a chipping hammer (not the point) or something simular. You can stimulate the wood grain. Quote Link to comment Share on other sites More sharing options...
Mende Posted August 18, 2008 Share Posted August 18, 2008 That be actually Cool! Keep it up ! Quote Link to comment Share on other sites More sharing options...
ptree Posted August 18, 2008 Share Posted August 18, 2008 I make lots of those little split crosses for demos. If I may, once in the form of a cross, use the hammer to flat down and put a litle side to side taper on each arme. Then use a somewhat sharp peen longwise to give a wood texture, and also fuller and spread the ends. Then brush and follow with a soft brass brush and bingo, you will be amazed at your own work. Keep at it. Everything gets easier after the first hundred:) Quote Link to comment Share on other sites More sharing options...
tbarm Posted August 19, 2008 Share Posted August 19, 2008 Nice cross!! Sounds like some good advice here also. I like the wood grain texture idea, I think I need to go back out to the shop again. Who needs to sleep anyhow? Quote Link to comment Share on other sites More sharing options...
