Jrfradella Posted December 17, 2020 Share Posted December 17, 2020 Steel is 80CRV2. I'm messing with my heat treat and have access to a Rockwell tester at work. Piece number 1 is a chunk of raw stock that I cut off, piece number 2 is a chunk that I normalised (10 minute soak @ 1600° ctb, 10 minute soak @ 1480° ctb, 10 minute soak @ 1250° ctb.) Piece number 3 was quenched in warm canola oil after normalizing then a 5 minute soak @ 1500°, piece number 4 was tempered twice after normalizing and quenching, first for one hour @ 375° second for one hour @ 400°. Piece #4 is right where I would expect it to be, around 59-60 HRC but piece #3 has me worried. I was expecting it to check around 64-65 HRC but it is barely checking harder then the piece that I tempered. Did I screw up somewhere? What would explain my quenched piece being the same hardness as my tempered piece? Quote Link to comment Share on other sites More sharing options...
Jrfradella Posted December 17, 2020 Author Share Posted December 17, 2020 Edit: my canola oil was only around 80° at time of quench. Could that be the culprit? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted December 17, 2020 Share Posted December 17, 2020 what happened when you repeated the experiment for #4? Quote Link to comment Share on other sites More sharing options...
Jrfradella Posted December 18, 2020 Author Share Posted December 18, 2020 I haven't had time to repeat it yet. I'm trying to figure out what I need to change for my next test. Quote Link to comment Share on other sites More sharing options...
