August 4, 20196 yr Hello. The new blower I have has an internal gate to adjust the airflow, but it is affected by the air as it pushes through. The air basically opens the gate no matter how I adjust the airflow. This is probably because the hinge of the gate is extremely loose. When the lever is pushed to the left on the pictures, it's 100% open and when it's to the right it's 0%. How can I make sure the lever stays where it is regardless of the airflow? The forge I'm building is in this thread. // Gustav VID_20190804_134719.mp4
August 4, 20196 yr Author Turns out you could adjust the airflow quite effectively with the ashdump and clinkerbreaker, so I just permanentley have the blower at full blast. Problem solved!
