SLAG Posted July 26, 2019 Share Posted July 26, 2019 I "inherited" an old rock solid pair of vise grip pliers.* It does not work. It needs a new spring. I have done a net search and found nothing. I checked out the vise grip site and several on-line vendors gleaned from a google search. I am not going to trash the tool. Does anyone know where I can get that spring? Thanks, SLAG. * It still has the U.S. patent number stamped on it. Those original vise grips sure were built solid. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted July 26, 2019 Share Posted July 26, 2019 Does it use the same spring as the newer versions? If so I found a bunch of places to get replacement springs in a couple minutes of searching. Amazon, EBay, and Irwin Tools all have the replacement springs for sale. Quote Link to comment Share on other sites More sharing options...
SLAG Posted July 26, 2019 Author Share Posted July 26, 2019 Mr. B.-Kill, Thank you very much for your quick response, and information. It is appreciated. I will check the spring on the pliers and compare it to one of my newer vise grips. Regards, SLAG. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 29, 2019 Share Posted July 29, 2019 You could always make one. I have made many springs for muzzleloaders and it's fairly easy. Quote Link to comment Share on other sites More sharing options...
SLAG Posted July 29, 2019 Author Share Posted July 29, 2019 IDF&C, Thank you for your suggestion. What alloy of steel do you use for your springs? Regards, SLAG. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 30, 2019 Share Posted July 30, 2019 To be honest, I don't know. I buy spring stock from several gun parts suppliers and go by thickness. I harden them in oil and temper with molten lead in my bullet casting pot set at 700 degrees F. Quote Link to comment Share on other sites More sharing options...
