March 20, 20197 yr Heyas folks, Any suggestions on what type of steel I should use for a 5.5" Scandinavian grind Bushcraft knife (simple heat treat)? Cheers! Nick
March 20, 20197 yr There is a list of suppliers here, I haven't bought any in a long time so I can't really recommend one. https://www.iforgeiron.com/topic/31605-supplier-list/
June 18, 20197 yr I'd recommend 1080/1084. 5160 would probably work fine too, but when doing my own research I often read that 5160 works better for larger blades because this steel is very tough but the trade-off is that it doesn't hold the edge as well, as 1084, for instance. However, since we are talking about a small bushcraft knife and not a chef's knife, the difference is probably academic. off site links removed
