1927 fisher anvil questions
I have a good shape fisher 1927 black hammer anvil.. But have some questions about the markings i know it weighs close to 500lbs.. It reads fisher 1927, then has 464 and 111 stamped into it.. What are the markings and what would a estimated value be on it?
464 should be the weight in pounds.
111 I hope Josh can set us straight on what that means.
Fisher is the Manufacturer  and 1927 is the date of manufacture---they had a warranty for  certain amount of time so date stamped them.
Price depends on WHERE IT IS; which you haven't provided. 150 countries participate on these forums on the World Wide Web; in some of them anvils are much cheaper than in others.  I will say that I bought mine in similar condition and similar weigh, 469 IIRC, for US$350 in Central Ohio USA, back in the 1990's and though I had a screaming from the rooftops deal.
Note Fisher, 1927 and 111 are not stamped into the anvil they are cast in place.  I assume that the 464 *is* stamped into the anvil up near the inset on the side????
Welcome to IFI... I always suggest reading this to get the best out of the forum. READ THIS FIRST
It would be an anvil from a Blacker power hammer that appears to be in excellent shape. If you edit your profile to show your location, as Thomas said it will help giving a value.
Yes the 464 and 111 are stamped near the top and im located in south west pa..thank you for the information on it
Posting pictures of the numbers in questions and their location would help identify what they are, maybe.
Yes I originally assumed the 111 was the markings to the right of the date (which I read as 110)
If it's up near the face and stamped in; I wonder if it's a blacker serial number as I've run into another that was stamped that was about 2 off of the number stamped on mine.
The raised marks near the date were codes used in the foundry for quality control.  They indicated the moldmaker, so if there was a problem with the anvil it could be traced back.
