March 12, 20197 yr I've been researching the web and all of the forums and I've had a small hiccup with my first foundry build. I built a box of dirt foundry and ended up burning through the bottom of it and caught it on fire a little bit. I plan on modifying it but I picked up a 20 lbs propane tank today that has a valve issue and I got to thinking. Does anyone have experience with pouring plaster of Paris and play sand mix over kaowool for use in a charcoal foundry I'm only going to be melting mostly aluminum, brass, copper and possibly try my hand at making some bronze or aluminum bronze in the future once I get more practiced. I'm just beginning my journey into metal casting but I've done a ton of research and I've read a few things about casting refractory over kaowool but not plaster/sand mix. I know its better to buy a tested refractory I was just looking at alternative options. Any advice would be appreciated and thank you in advance.
March 12, 20197 yr STOP plaster of paris may be fine for lead and tin, but not anything like bronze or copper read more before building
March 12, 20197 yr Author Okay thank you Steve that's what I was wanting to know I seen several youtubers that claim plaster would work and several ppl say they use it on other forum sites I think I'll find some refractory to pour over the kaowool instead
March 12, 20197 yr Just a thought, most of the how to do it You Tube videos are down right dangerous, by folks who have no idea how to safely do what we do.
March 12, 20197 yr Author Yeah I figured as much irondragon that's why I turned to the most experienced group of ppl I knew to ask
