Need help identifying anvils
Hello all
I got a hold of two anvils , but I am unable to identifying them. The larger I was told is 65kg the smaller is 45kg.
I have looked all over both, wire brushed and used chalk.
I even tried useing paper and pencil to try get some imprint but found nothing but some numbers.
The numbers is at the bottom of the larger one , but it made me no wiser. It seems to be stamped upside down with 8 30 8 or 80 3 8 read right side up ... but it just confused me :D
I will add a few photo of both with measuring band in hope that someone can help me here .
C8B4B6AC-8E63-4E55-9140-835CCEE81705.thumb.jpeg.8ae11827505450b7805da5b1b5af7c61.jpeg036103D1-6358-4B2C-A695-8725E2816E10.thumb.jpeg.1c3708ab1c82de35f79ce2d88e72bcb5.jpegDE5B7C76-F193-4956-9576-C1427D20C5E4.thumb.jpeg.60f1758d94ba0f7e3bc32a6fcdfc040f.jpegA436223B-DD96-4467-93F1-8EB94BA40578.thumb.jpeg.e0420850d17a4c6f1a264d944a7cc6d7.jpeg73CCF78A-B3F4-45D2-9B0C-5AF84CC6961E.thumb.jpeg.db3fbbf75e1023d595621836fac383fd.jpegB4F4E7BA-45A1-4BC1-BCAC-370418150F57.thumb.jpeg.a98c86725003c700677b1167b7a9b9a7.jpeg8F26BD52-2E8C-44C5-908E-3181DA84B4A9.thumb.jpeg.15254c16005dd5869b00e8aafb5cdf51.jpeg2980C2BF-84E5-411E-804E-9D9BF66C4552.thumb.jpeg.cc74ac3143a95be6697dd63eca6b132f.jpeg
   Nice start. First anvil 65KG is Swedish cast steel, most likely a Kohlswa. Very classic Swedish pattern, similar to a south German pattern, typically more narrow.
  The second anvil 45KG, is a north German pattern, makers mark usually on the other side, round horn facing right.
   N.N.F.              Beautiful, Manchester, Michigan. USA
The 65kg. looks like a fine daily user. I'd put it to work as it is, all she needs is a stand. The 45kg. looks like she's been worked hard still a nice anvil, plenty of years left in her.
Good scores!
  After a closer look, bigger screen. I would say the 65KG anvil is a Soderfors. In the third picture down, what I thought was a K for Kohlswa, looks more like a K for kilograms. With possible date, stamped 1911, under the weight. Swedish anvils historically stamp both sides, possibly more markings.
   As Frosty said, most importantly a very good user.
Thank you for the help, I was real puzzled with what the markings would be.
It seems clearer in the photos , in daylight all the marks from smiths testing tools on it threw me off.
I also put it on a scale,the seller was a bit off on the weight, since it is almost 59kg , so I would assume it was around 60kg new.
Yeah , that anvil sure has seen some use and abuse trough many years.
I will be careful and not hammer to hard on the horns.
Out of curiosity , what are anvils like this worth ? These are the only two I have found in my area, the fella wanted 280$ if I took both , so that’s what I gave him . Is this to much or about right ?
This is the other side of the anvil, personally I can’t se anything coherent , but you might know what to look for :D
