Acronyms and Abbreviations
Glenn
Acronym: an abbreviation formed from the initial letters of other words and can be pronounced as a word.
55 Forge A solid fuel forge constructed from a 55 gallon metal drum
A2 air hardening steel, ASE name
ASO Anvil Shaped Object
AWS American Welding Society
BLEVE- boiling liquid expanding vapor explosion
CR or CRS  cold rolled steel
DCEP (DC+) Direct Current Electrode Positive, welding rod
DCEN (DC-) Direct Current Electrode Negative, welding rod
FPM Feet Per Minute
GMAW gas metal arc welding, wire feed welding
GTAW Gas tungsten arc welding
GTTS Go To The Source
HC High Carbon, content of carbon in steel, expressed as a percnet
HF Harbor Freight
HR or HRS hot rolled steel
HT Heat Treating
IFI IForgeIron
JABOD Just a Box of Dirt
KSO Knife Shaped Object
MIG metal inert gas, wire feed welding
Mod Moderator
NA Normally Aspirated, air intake associated with gas forges. Also known as Naturally aspirated.
NARB Normally Aspirated Ribbon Burners, gas forges. Also known as Naturally aspirated.
OHIO  Only Handle It Once
OP Original Poster
PIF pay if forward
PPE Personal Protection Equipment
Porta-BOD Portable Box Of Dirt, solid fuel forge
RPM Revolutions Per Minute
SMAW shielded metal arc welding, electric welding
SSO Sword Shaped Object
TIG tungsten inert gas arc welding
TPAAAT Thomas Powers Applied Anvil Acquisition Technique
W1/W2 water hardening steel, SAE name
Welding Rod Numbers The “E” indicates an arc welding electrode. The first two digits of a 4-digit number and the first three digits of a 5-digit number stand for tensile strength. The next to last digit indicates position. So, “1” stands for an all position electrode, “2” for a flat and horizontal electrode, and “4” for a flat, horizontal, vertical down and overhead electrode. The last two digits specify the type of coating and the welding current
WI Wrought Iron
We will try to keep the list in alphabetical order for ease of use. If you see any more, please post them so we can add them to the list. The post will then be taken off line in order to keep the list and thread clean and to the point.
  • 11 months later...
Glenn,
I seem to be confused, (normal) about NA and NARB. In the Abbreviations above shows "N" to represent "Normally".
I have seen this usually used as "naturally" aspirated.
Are these terms interchangeable?
George
Yes.
Similar to  cars, a naturally aspirated engine, sometimes known as a normally aspirated engine, is an internal combustion engine in which oxygen intake depends solely on atmospheric pressure and does not rely on forced induction through a turbocharger or a supercharger.
