Golden_eagle Posted May 19, 2008 Share Posted May 19, 2008 I have been looking at DIY Welders/Cutters and have Happened across HHO Cutting torches, My question is Can you weld with them and where can you get them? Quote Link to comment Share on other sites More sharing options...
Joe H Posted May 20, 2008 Share Posted May 20, 2008 Short answer : not really. Not that they don't work, jewelers have been using them for years. They are impractical for anything other than brazing small objects. Also, the moisture from burning hydrogen will cause hydrogen embrittlement when welding. You can't cut with them either, not without a tank of oxygen from the LWS at least. It takes a large excess of oxygen to do any cutting, the HHO systems only produce enough for a nuetral flame. There is alot of hype around these things lately. In reality they are only useful for very specific applications. You are much better off with O2 and acetylene, or even propane. :) Quote Link to comment Share on other sites More sharing options...
ornametalsmith Posted May 20, 2008 Share Posted May 20, 2008 Just thought I'd toss this out there:YouTube - Hydrogen Technology And their website, which has other interesting videos:Hydrogen Technology Applications, Inc. I've got an invitation to go down and Play with the TOYLS.......I'll post a first hand experience report afterwards. Quote Link to comment Share on other sites More sharing options...
Joe H Posted May 20, 2008 Share Posted May 20, 2008 The very first line in that youtube video says it all. "(whatever his name was) shows off his hot new invention". BS! These things have literally been around longer than I have. Yes, you can make a torch that runs off of water (and LOTS of electricity). Is it a very useful torch? Nope. That's why you only see them on the internet. Quote Link to comment Share on other sites More sharing options...
Golden_eagle Posted May 21, 2008 Author Share Posted May 21, 2008 What about Browns gas? Quote Link to comment Share on other sites More sharing options...
bipolarandy Posted May 21, 2008 Share Posted May 21, 2008 Browns gas is the same as Klines gas is the same as HHO gas, every 10 or 20 years another scam artist come along and puts his name on it and sells it as brand new state of the art tech, Water powered torches have been around for 100 years, why dont people use them? They take tons of electricity and are not as hot as a O/A torch Quote Link to comment Share on other sites More sharing options...
ornametalsmith Posted May 21, 2008 Share Posted May 21, 2008 fwiw, The technology works, there are many water torches used in the jewelry field, which was where I first saw the Aqua Torch(mid 80's). They don't use "tons of electricity". Can you get your O/A torch to burn at almost 5800 degrees? Mine won't. :confused:Flame temperatures * 2200 Quote Link to comment Share on other sites More sharing options...
Golden_eagle Posted May 28, 2008 Author Share Posted May 28, 2008 (edited) the one I'm working on has a three gallon water reservoir and one-gallon aniti-spark HHO holding tank, and the main flashback arrester is right next to the torch: the torch it self is a pre-made factory torch. it runs off a rectifyed 110 wall current and draws 1-25 amps depending on what your doing... P.S. bipolarandy i knew that browns gas and HHO are the same along with Hydroxagen, but Klines gas i dident know about, thanks! Edited May 28, 2008 by Golden_eagle left out power source Quote Link to comment Share on other sites More sharing options...
h2extreme.com Posted September 30, 2008 Share Posted September 30, 2008 I have been looking at DIY Welders/Cutters and have Happened across HHO Cutting torches, My question is Can you weld with them and where can you get them? hho for welding is not a choice I would use. although i do build these and would love to sell you one. the heat from the hho burns the steel and makes it crisp. some bubble acetone to cool the flame, but why not just use a plasma arc welder. believe me i've done both. you can check out my torches and videos at water for fuel Quote Link to comment Share on other sites More sharing options...
Joe H Posted September 30, 2008 Share Posted September 30, 2008 It's not the heat, it's the hydrogen that makes the steel brittle. It's called hydrogen embrittlement. Moisture can cause it in any welding process. Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted October 1, 2008 Share Posted October 1, 2008 I thought I remembered O/A getting hotter than was said above. Googled it and found Acetylene alone may reach 4000f adding oxygen 6000f Quote Link to comment Share on other sites More sharing options...
