Ryan Attoe Posted April 9, 2018 Share Posted April 9, 2018 Hi all, I'm new to the site, but am really looking forward to digging through the forums. I've searched as best I can figure for the anvil below, both here and online, but can't seem to locate any information about it. I was hoping that someone might have come across this brand. I'll attach some pics. It says Smith's England, on one side, and has the number 3 stamped on the front foot. I was wondering if anyone can point me towards any more information about the manufacturer, or factory location. Oh, and it weighs 120 lbs. My grandfather would have acquired it from a blacksmith shop at the government dock at Oak Point, NB in about he 50s. Thanks Ryan Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 9, 2018 Share Posted April 9, 2018 Welcome to IFI... I always suggest this thread to get the best out of the forum. There are many here that know a lot more about anvils than I and I'm sure they will weigh in shortly. It will help greatly to know where it is located. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 9, 2018 Share Posted April 9, 2018 England stamp usually means after around 1900 when a country of origin law went into effect in the USA. Should be weight stamped in the CWT system so 120# would be 1 0 18 but stamped weight and zactual weight may vary by a couple of pounds Smith anvils are mentioned in Anvils in America pages 68 and 75 but Postman has not seem many of them. Please remember: wire brushing is fine but any grinding or milling or welding on the face can drop the worth by 1/2 or even more! Quote Link to comment Share on other sites More sharing options...
Ryan Attoe Posted April 9, 2018 Author Share Posted April 9, 2018 Thanks for the tips Irondragon. I just read the suggested topic, and added my location to my profile ( Hamilton, ON), and searched google for "iforgeiron smith's england 3". It still didn't give me anything useful, but the tip will help as I navigate on other topics. ThomasPower. I'll try to track down a copy of Anvils in America and see what they've got. Thank you for the suggestions. I've hit it lightly with a flapper disk to get rid of some of the rust, though I left about a third of it because I didn't want to start removing any metal. I won't do anything else to it till I've chained it to a stump and used it for a good long while. In fact, I probably won't do anything to it until I've found someone who really knows their stuff and they suggest a change. Quote Link to comment Share on other sites More sharing options...
Ryan Attoe Posted April 9, 2018 Author Share Posted April 9, 2018 Thomaspower. I had dismissed the tool marks on the other side, but it is as described about the weight. Thanks for the help. Does anyone think I need to worry about the visible crack along the bottom, or the ridge line under the face Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 9, 2018 Share Posted April 9, 2018 44 minutes ago, Ryan Attoe said: added my location to my profile It must have not been saved, it should show up under your avatar. What looks like a crack is where the steel face was forge welded to the base. One way to tell if it's a problem is to test the ringing with a small ball pien hammer. If the ring is consistent over the whole face it is ok. OOPS Thomas replied while I was adding to my post. BTW it looks like an excellent anvil, ready to go to work. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 9, 2018 Share Posted April 9, 2018 if the ring is good and clear then no crack problems---you may see the line from the forge weld of the face to the body. Quote Link to comment Share on other sites More sharing options...
Ryan Attoe Posted April 9, 2018 Author Share Posted April 9, 2018 The ring seems consistent across the face, so I guess nothing to worry about. Irondragon: I tried again with the location under profile, and then hit save. Still nothing. I'll have to take another look at it tomorrow from another device, and then contact the admin if I can't get it to work. I can see the advantage of people being able to figure out who's close by. I'll post photos after I've got it mounted and I build some hammer & tong storage. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
