19Branden86 Posted January 11, 2018 Share Posted January 11, 2018 I've got 2 coats of refractory on a 1 inch layer of kaowool. Gives me about a 4 inch opening on either end of the forge. Gives me just under 88 cubic inches of volume. And, as you can see, I ditched my first burner in favor of Frosty's Venturi T burner. That's my first time working with refractory and was almost aggravated because of the fact that it looked like wet sand but discovered after some reading that it's not sand but rather a mixture of sodium silicate and the gritty stuff is aluminium oxide and crystalline silica. Now all I need is to let it dry and finish putting together the brass gas line that connects to the burner and it's ready for forging! Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 11, 2018 Share Posted January 11, 2018 so about 7" long with 4" diameter gives you about 82 cubic" My questions is what size burner is that? It looks like a 3/4" if i'm right on that its WAY overkill for that forge. To the point that you might melt more metal then you forge. Also a couple quick side notes. I can see your blanket in the burner port. You realy should consider covering that will refractory for safety (a thin layer is more then enough for a burner port) Also I realy hope that blanket is ridgidized. And i'm not noticing any way to actually mount the burner. Quote Link to comment Share on other sites More sharing options...
