November 13, 20178 yr Hello all. I'm looking to know is it possible to quench in vegetable oil and or frying oil . Have the availability of both just don't know if any good and wouldn't use unless it was. Thanks Gareth.
November 13, 20178 yr Absolutely. Smells a lot better than motor oil. Keep it covered when not in use- it will attract varmints. Steve
November 13, 20178 yr Yes, and yes. The purpose of a quench medium is to remove heat from the steel quickly. Different alloys need different quenchants to get the most out of steel. Heated vegetable or frying oil should work fine for any alloy for which an oil quench is suitable.
November 13, 20178 yr Almost time to get some free slightly used peanut oil after thanksgiving here in the states. Tho, using it to quench makes me hungry for some reason.
November 16, 20178 yr Author Thanks everyone for there replys all good information, will be able to make good use of this oil now ! .
