Binesman Posted October 11, 2017 Share Posted October 11, 2017 Burner is 10" long 3/4" diameter. Using a machined #60 hole to feed with 16 1/2" holes. I have made 4 of these prior to this one all work great. For some reason this one is running very rich. Any suggestions on how to correct this? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted October 14, 2017 Share Posted October 14, 2017 More air simply requires enlarging your present holes and/or increasing the induction rate of your burner (stronger nozzle and/or stronger gas stream ). The easy way to vary the gas stream is with MIG contact tips. Otherwise, drill a smaller hole. Quote Link to comment Share on other sites More sharing options...
