Max Mulholland - Tetnum Posted March 15, 2008 Share Posted March 15, 2008 i have a small forge that constantily pluggs up with some form of clinker but not in the fire pot bit in the chimney and it has compleatly plugged the pic of buid up below along with video of forge please any suggestions on how to fix this problem are invitedYouTube - forge tour thankyou Quote Link to comment Share on other sites More sharing options...
Dave M Posted March 15, 2008 Share Posted March 15, 2008 I looks like the impurities in the coal that you are burning are being converted to a gas form that is then condensing when it comes in contact with your cold chimmeny. I use to have this problem when I use to burn hard coal, now I only burn soft coal. 1 trick that I learned is to start a very hot wood or paper fire first, this will preheat your cimmeny and it will also help with the draft of the chimmey. Quote Link to comment Share on other sites More sharing options...
Max Mulholland - Tetnum Posted March 15, 2008 Author Share Posted March 15, 2008 i dont know if this has any effect but i burn charcoal dueto lack 0f coal on MO Quote Link to comment Share on other sites More sharing options...
kevan Posted March 15, 2008 Share Posted March 15, 2008 Whatever it is , I hope you don`t get too much of it into your lungs! Remember, your health is your wealth. Quote Link to comment Share on other sites More sharing options...
nett Posted March 16, 2008 Share Posted March 16, 2008 I suspect your mud is way to wet. The surface inside your chimney may appear dry, but there is moist clay just below the surface that is heating to a boil (steam) and pushing (spalling) the face. These fallen chunks are clogging your chimney at the firebox, the bits closest to the fire are actually being fired into a ceramic material, like a brick. Try again with sticky (drier) clay and let it dry for a few days to further reduce the moisture. Start with a small fire (wood kindling) to help cure and dry the clay, then work up to the bigger ones. Any cracks that appear (expect cracks) during this time are easily repaired with more clay. Give some though to identifying the difference between soil and clay. Clay is good, while soil, with organic material in it, is not as good. Second time is charm! Good luck. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted March 16, 2008 Share Posted March 16, 2008 Missouri has coal. They also are a major mfgr of charcoal. I use both. Following link will get you to the coal and educational help:Blacksmiths Association of Missouri Quote Link to comment Share on other sites More sharing options...
Glenn Posted March 27, 2008 Share Posted March 27, 2008 When the air to the forge slows down, it is time to dig out the clinker. There was another piece about half this side in the forge also. Just dig it out, remove most of the junk and ash and rebuild the fire. Takes only a couple of minutes. Quote Link to comment Share on other sites More sharing options...
