March 2, 200818 yr Hi I am new here and I have a question or 2. I am making a air hammer with 2dual acting cylinders. I want both cylinders to be extended when I have no presure on the valve'(s), when I aply pressure to the valve'(s) I want them to both close. Is there a single valve that can get this done or do I need 2 valves, that are 2 position 4 way directional? Will 2 of this e-may item # 190156572291 work? If you know what I mean, and know what I need please post, or pm me. Also the material for the dies I chose S-7, what hardness should i shoot for? I should have the steel by the end of the week, and would like to get that valve asap so I can get this wraped up. Thank you all for your help, Michael... :confused:
March 5, 200818 yr Hi Michael, I can't help you in the least, but I bet there are folks here who will have some ideas. I look forward to following your thread. Thanks for the questions. Your project sounds great. Hope you post some photos of it. Where is Parma? All the best, Phil
March 5, 200818 yr C there are a couple of professional air hammer builders that hang out at forgemagic.com. You may want to ask this question over there.
March 6, 200818 yr Author I live on the east side of Parma off State south of Snow. A long way from Hawaii (Oahu), I would trade spots in a second, interested? As far as valves go, I just bought 2 of basicly every kind made that is non- electric. I want to make sure I have what I need when I start. I hope to get the info I need. But if not I'll figure it out. I will check out forgemagic.com. I will also post picks. My design is basicly a ka75.com, but beefed up quiet a bit. It will basicly be the same but centerd in the middle of a four poste linear slide, and both cylinders will drive up and down. I should have the steel by the end of the week. They are wating actualy for the S-7, so I will pick it up when they have the whole order. To start I am only making one die set, just flat. I think I will be able to knock out the fab in 6-16 hours, well we'll see. The valving will probably end up being the part that takes the most time. I can't wait, I love building new things. :)
March 7, 200818 yr Oops, forgot that small detail. That would be Ohio. Hey there! I'm from Grafton, Ohio! If you ever want to get together to do some blacksmithing, shoot me a PM here on the forums or email me- [email protected]
