zak54 Posted June 20, 2017 Share Posted June 20, 2017 Hi guys, Just got started building a forge from a 20 lb propane cylinder, the plan that I'm following I found on line. I have two questions... 1. Most of the propane cylinder forge designs I've seen show the burner entering the cylinder at an angle....is this necessary, or can the burner enter from the top and point straight down? 2. With 2" of kaowool throughout as insulation and sealed with ITC 100 would one burner be sufficient for a forge this size? I'm thinking the chamber to be heated will be approx. 8" x 8" in size? Thanks for any advice you may have.u Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted June 21, 2017 Share Posted June 21, 2017 Gas Burners for Forges, Furnaces, & Kilns has an entire chapter showing you how to build a forge from a five gallon propane cylinder, including how and why to position your burner. You can find a pirated copy online for no money. Quote Link to comment Share on other sites More sharing options...
