March 1, 200818 yr I want to produce 10mm box spanners. How are they made? Do they pour hot metal into moulds or are they machine made? Is it something I could have a go at? Any suggestions. Regards Jim
March 1, 200818 yr Here is one of several methods Forge-practice and Heat Treatment of ... - Google Book Search a Google book search of blacksmithing will lead you to many wonderful old out of print books that were instruction books for the old timers. Here on IFI is just a samplehttp://www.iforgeiron.com/forum/f7/free-blacksmithing-books-web-2032/ enjoy
March 1, 200818 yr Box spanners were originally tube with the ends forged down to the size required, and a couple of holes drilledthrough at 90 degrees to each other for a tommy bar to fit through to enable the nut to be undone or tightened One way of doing this is to flare the end of an appropriate sized tube then forge it down around a nut/ hex bar of the same size you require it to fit
March 1, 200818 yr Author I didnt realise that it all starts with a tube, knowing that makes it very easy. What I want is a 10mm box spanner attatched to a screwdriver type of handle. I dont know what you call them but they are abundance up to 8mm but I cant find 10mm. I will keep you posted it is going to be a bit of a learning curve, looking forward to it.
March 2, 200818 yr The term you are looking for is a nut driver. Sears sells them here in the states. Interesting idea let us know how it turns out.
March 2, 200818 yr What I want is a 10mm box spanner attatched to a screwdriver type of handle. I dont know what you call them but they are abundance up to 8mm but I cant find 10mm. as the diameter increases on a bolt the leverage required to tighten and loosen increases as well, setting an upper limit to axial leverage as seen in a screwdriver type handle, while it maybe very handy for starting the thread, Id retain the typical through hole in a box spanner so you can add a lever when needed.
