June 15, 20179 yr What do you guys think about this one? Anvil M&H Armitage - $450 marked 1-0-0 Craigslist link removed
June 15, 20179 yr Even in the states it might be a tad pricey, even as a museum piece. If you lived in the UK you could have my 250lb mousehole for $400. Depends whether the area you live in is rich in anvils or not; probably better to hear the opinion of someone closer to your area.
June 15, 20179 yr US $4 a pound, at 112 pounds is a very popular size. If the face is in excellent shape with no signs of damage, repair or grinding/milling then in your location it is OK. If it's worn/damaged/repaired I'd pass on it unless you are desperate for an anvil. Without pictures it's rather like asking us if a used 2 door ford car is a good buy at $4000---could you make a judgement on just that?
