February 28, 200818 yr This is a spill over from the "it followed me home" thread concerning using MIG to weld A) larger pieces the hydraulic piston I want to use for my treadle. I'm, not trying to beat a dead horse, just hoping for more info as to how MIG capabilities and drawbacks. Using my high quality drawing as reference. If I weld around the base and also weld both sides of the triangle supports. Plus I plan on having 2 horizontal supports from the rear pivot upright connecting to the anvil post. Is it a good or bad idea to weld both sides of a piece like this?
February 28, 200818 yr Your design should work fine. Most problems with distortion are for excessively long welds done all at once so it often helps to "stitch" a weld for an inch or so, then go to the back side but advance to a linear position where the first weld would have continued. Repeat the process until done. This allows the stress to balance out and prevents gross movements in the pieces. Just to see what would happen, I once welded two pieces of steel that were about 3 feet long, all on one side, unrestrained and one continous bead. When complete, the start of the weld had pulled almost 2 inches out of the flat position.
February 28, 200818 yr Author Thanks HW, what was discussed in the blacksmithing folder, "it followed me home" http://www.iforgeiron.com/forum/f7/followed-me-home-51/index70.html was that MIG should not be used in this application as it would / could get a "cold lap" MIG welding on this shaft is NOT the way to go. These things do not bend, hence the pivit points on both ends. 1/2 day rental on a machine is cheap, will save at least time in the long run if not saving an injury. MIG is a very desceiving process, what looks good to the eye and even an X-Ray can often be a bad weld when put to a bend test. X-Ray is the EASIEST test to pass in welding. (no matter the process) It does not show non-fussion or 'cold lap'. The material Larrynjr is wanting to use has very tight parameters that should be strictly followed if you are to weld it. AND, he openly states he has Zero experience in welding. Know what you are working with before you say, "OH, I'll just MIG that up." could bite you in the backside someday. Don't misunderstand, I LOVE my MillerMatic 250 and use it when I can. (I use a 454 Miller with dual guns ,one for MIG one for FCAW, at work...sweet machine ) But, after nearly 35 yrs experience, I know when and when not to pick it up. This case, IMHO, is a "when not". What I'm wondering is if welding each side of the triangle would prevent or make worse any cold lapping tendenances. Being the complete welding novice that I am, I'm just trying to understand as much as I can before I start messing with things best left unmessed.
February 28, 200818 yr I think your desighn is fine. Not having any experience, I wouldn't recomend welding it your self. I don't think your mig is heavy enough. I've welded large projects with a mig, but I had wire desighned to do the job and a machine large enough to handle the load. Why not look around and find an experienced welder and make a trade of work for work.You might even pick up another forging freind. I was always told "You can't beat a man at his own game" Just suggestions Travis
February 28, 200818 yr Larry, heed Thomas's advice. From the pictures you took of your welder, it looks to me like it's a Northern Tool Mig 135, this is a 110 volt unit with a 20% duty cycle, you will get nowhere near the proper penetraion with this machine needed to hold things together even with pre-heating. That small of a machine will not cut it, it is probably rated to weld 5/16" mild steel at max with flux cored wire, you might could get up to 3/8" with a bottle of gas but I would not want to be around anything that something could come loose on a possibly hurt someone or yourself. I have a small lincoln 140 in my shop that I use to tack and weld stuff 1/4" and smaller, for anything thicker or that is structural I pull out the Ac-225 buzz box or the Champion 10,000. Just my .02, I was reading on the other thread what you were planning to do and would take Thomas's advice.
February 28, 200818 yr This is off another site, on a motorcycle frame where the down tubes go into the steering neck, this snapped off going 60mph down the highway, luckily the rider wasn't injured, the frame was built by a "professional" motorcycle frame building company. Nowhere near the thickness of that shaft you have, you can clearly see that things might look good on the outside but the inside is a whole nuther story.
February 28, 200818 yr Very good photo Plop, That's a great example of how it was just weld bead on the outside, but the actual surface of the bar itself was never actually welded to the other bar / frame, more held in place ala hot glue.
February 28, 200818 yr "professional" There are lots of professional companys out there that build stuff to look pretty and don't have a clue on real welding. I see it all the time in magazines and on TV. But i would use a bigger mig than yours. If it warps up after welding which it will just heat the bottom a little and it will coll and pull back flat...Bob
February 28, 200818 yr Couldn't agree more about the "professionals" aametal, and it seems to be getting worse.....
February 28, 200818 yr To play devil's advocate for MIG welding , every light pole and transmission structure(that isn't still wood, that is) that you likely drive by especially if you frequent any of Sam Walton's stores has been welded with a wire fed process; be it MIG or submerged arc. We used MIG for the smaller poles and SMAC for the larger. *BUT* (here comes the disclaimer LOL)These were commercial 440-480 volt, 450amp, 100% duty cycle.
February 28, 200818 yr OK - I did not follow the other thread so therein lies the disconnect on my part. However, to be fair, we should further divide MIG into subprocesses. A great deal of large industrial products are made with MIG spray arc so the basic process is sound for heavy weldments. Of course, you can't get there from here with less than 200 amps and a high percentage of Ar in the shielding gas so you are either pulsing or short arc - both of which yield less penetration. A 135 amp unit would most certainly not provide much penetration in a critical application and welding from both sides.
February 29, 200818 yr Author Thank you all for your input, I plan on following Thomas's advice. The Ag teacher has agreed to show me how to weld both stick and mig, next month after he clears all the wood out of the shop. My point wasn't to question Thomas's advice but just to get more info on the whole process. Like most of us here, once I get a little info I have to keep scratching at it, trying to find out more! I kick myself now, I took basic metal shop in HS and hammered out a cold chisel but stopped there and didn't take the advanced metal to learn welding. DOH!!!
February 29, 200818 yr You know what they say....a little knowledge can be dangerous! That's great you have this Ag teacher to help you learn. It will save you TONS of hair pulling in the future. Once you see what you can and can't weld with MIG you will be looking for a stick machine. Check out craigslist classifieds: jobs, housing, personals, for sale, services, community, events, forums in your area. I know there are GOOD machine list in our area all the time well worth the $$. May be used, but most of the older machines will last way longer for no more than you will problably use it. Good luck. can't wait to see your finished hammer.
