JMForge Posted March 30, 2017 Share Posted March 30, 2017 I'm wanting to build a forge from a brake rotor forge and sheet metal, I'm trying to understand what gauge of sheet metal I should use. Link to comment Share on other sites More sharing options...
SBLumberjack Posted April 2, 2017 Share Posted April 2, 2017 I used 1/4" plate for the fire pot. I made some refractory cement from fireplace ash. I've fired it up a few times and so far so good. Link to comment Share on other sites More sharing options...
Will W. Posted April 3, 2017 Share Posted April 3, 2017 JMForge Gauge of sheet metal for what exactly? The tuyere? Or the top of the forge where coal will be put? Obviously you're not talking about your firepot, as you say your using a rotor for that. We need more details of what you're planning. Link to comment Share on other sites More sharing options...
JMForge Posted April 4, 2017 Author Share Posted April 4, 2017 sorry about that i should've made it clearer. Yes I'm talking about the top plate where ill be putting coal and holding the rotor. I'm planning on using 1 1/2 inch black pipe with a t section to create my tuyere and a pvc ball valve to control my air flow as ill be using a single speed bathroom vent fan as my bellows. Link to comment Share on other sites More sharing options...
arkie Posted April 4, 2017 Share Posted April 4, 2017 JM, my table is made from 1/4" plate, and holds a brake drum fine. I have heard some use 1/8" sheet but you might need a brace across the bottom to prevent sag when it gets warm. I saw a brake drum forge this weekend that a guy made in about an hour from a stainless steel, two level food table/cart on wheels. It was about 18" x 30". It had a fairly thin top and the guy unscrewed it, flipped it over and the lip around the edges held his coal in. Even the thin stainless held the drum arrangement fine. They may have to brace it underneath later. Link to comment Share on other sites More sharing options...
Will W. Posted April 4, 2017 Share Posted April 4, 2017 JM My table is 3/16". Works pretty well, I think. I second everything arkie said as well, regarding bracing thinner steel and sagging. Link to comment Share on other sites More sharing options...
Please sign in to comment
