March 24, 20179 yr This is where it stands so far. The anvil is a slim 15 pounds, while the stand, with hollow legs at present, weighs 73 pounds. I have lots of space around it for tool hangers, etc., but that can happen later.
March 24, 20179 yr That is the handsomest rail anvil I have ever seen. When you upgrade anvils, I think that one will bring a pretty penny.
March 24, 20179 yr Cool looking. Did you put the pritchel and hardy holes in it. If so, how did you do it. I would like to see a picture of the horn. That must have taken some work. It looks really good
March 25, 20179 yr Author Thanks a lot guys! I think I just needed to make it for the experience of making it. The hardy is anything but perfect, I made 5 pilot holes of 1/8" diameter then stepped up the center hole to 1/2". Afterward it was just a matter of using the Dremel tool and a carbide cutter to get close enough.
